How To Allow Internet Browing On Cisco 1721 Routerq, Need Help
Jul 27th, 2007
Dear Guys...
I have two Routers One is connected to other through VPN on different cities...
VPN works well i m able to access the LAN on both sides... BUT I CAN NOT BROWSE THE INTERNET
this is the major problem in my network.....
How can i do it...
I have Router 1721 Cisco...
Thanks in Advance... Okies
Dear Guys I have the Router Configuration given below but i can not browse the internet while the VPN works well..
User Access Verification
Password:
hyderabad>en
Password:
hyderabad#show
hyderabad#show ru
hyderabad#show running-config
Building configuration...
Current configuration : 1818 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname hyderabad
boot-start-marker
boot-end-marker
enable password xxx
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
no ip domain lookup
isdn switch-type basic-net3
interface Tunnel0
description link to karachi
ip address 192.16.10.21 255.255.255.252
load-interval 30
keepalive 5 3
tunnel source 203.x.129.243
tunnel destination 124.x.244.141
interface BRI0
description connected to internet
no ip address
ip nat outside
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn point-to-point-setup
no cdp enable
interface FastEthernet0
ip address 13.x.x.10 255.0.0.0
ip nat inside
speed auto
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
no ip split-horizon
dialer in-band
dialer string 13131212
dialer hold-queue 10
dialer load-threshold 10 outbound
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname rdpmuhyd
ppp chap password xxx
ppp pap sent-username rdpmuhyd password xxx
ppp multilink
router rip
version 2
passive-interface Dialer1
network 13.0.0.0
no auto-summary
ip nat inside source list 1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 0.0.0.0
ip route 124.29.x.x.255.255.248 Dialer1
no ip http server
no ip http secure-server
access-list 1 permit 13.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
snmp-server community public RO
line con 0
exec-timeout 0 0
password xxx
login
line aux 0
line vty 0 4
password xxx
login
end
hyderabad#
hyderabad#
mohammedmahmoud Fri, 07/27/2007 - 23:12
  • Green, 3000 points or more
Please modify the default route "ip route 0.0.0.0 0.0.0.0 0.0.0.0 " to reflect the actual next-hop for your internet.
HTH,
Mohammed Mahmoud.
purohit_810 Sat, 07/28/2007 - 11:04
  • Silver, 250 points or more
You should have make two changes:
Change it:
ip nat inside source list 101 interface Dialer1 overload
Same 101 statement sould have to allow into
dialer-list 101 protocol ip permit
Dharmesh Purohit
purohit_810 Sat, 07/28/2007 - 11:05
Access-list also should be extended.
Dharmesh Purohit
