Jon Marshall Sat, 07/28/2007 - 01:16
Could you post output of "sh ver" and also post the configuration commands you are using to configure pim.
Jon
vipinyadav84 Sat, 07/28/2007 - 01:21
Cisco IOS Software, C3560 Software (C3560-IPBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 07:19 by yenanh
Image text-base: 0x00003000, data-base: 0x00EB0F14
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
GoldstoneTechnologies uptime is 2 weeks, 1 day, 3 hours, 8 minutes
System image file is "flash:c3560-ipbase-mz.122-25.SEE2/c3560-ipbase-mz.122-25.SEE2.bin"
cisco WS-C3560-24TS (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID CAT1108ZJ1N
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1A:E3:EF:41:00
Motherboard assembly number : 73-9897-06
Power supply part number : 341-0097-02
Motherboard serial number : CAT110850YV
Power supply serial number : AZS110410N6
Model revision number : D0
Motherboard revision number : A0
Model number : WS-C3560-24TS-S
System serial number : CAT1108ZJ1N
Top Assembly Part Number : 800-26160-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COMMG00ARB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3560-24TS 12.2(25)SEE2 C3560-IPBASE-M
Configuration register is 0xF
interface vlan 1
ip address 192.168.3.10 255.255.255.0
ip pim dense-mode
Jon Marshall Sat, 07/28/2007 - 04:01
You have the IP Base image which does not support multicast routing.
You need the IP Services image to do this.
Jon
