VPN Client 4.0.1 - enable start before login issues
Jul 28th, 2007
I work for a large company on a domain and several users are experiencing this problem. The cisco vpn client will not start before login. The checkbox for enable start before login is checked. This is on a Windows XP machine.
johnd2310 Mon, 07/30/2007 - 01:33
  • Silver, 250 points or more
Have client versions be downgraded recently?
John
mkumpel2004 Tue, 08/21/2007 - 14:22
This has happened on several machines. It is hit or miss. All the same model laptops (Dell D620). We use client version 4.0.1. Same version that everyone uses. I thought it may have been something with the SMS images; however, like I said it works on one and then it doesn't work on another with the same image.
