Need help, with calling number
Jul 28th, 2007
Hy guys, I have this problem with one of clients, he is sending a call to my cisco AS5300, the call is getting translated well, and goes out to the other switch where it has to get billed, but on another switch the calling number is comming wrong or empty, than the billing does not recognieze it. and rejects the call. this is the config.
voice translation-profile hyphenin
translate calling 6300
translate called 63001
dial-peer voice 6300 pots
trunkgroup CARR-IN
translation-profile outgoing hyphenin
destination-pattern 12345
and this is the call log,
as you see the calling number is abc12345
I tried to send the call to the cisco without abc, only the 12345, and
it worked well, so now I asked that client to change he's calling number
but he cannot do it. in he's device.
i need some how to make sure that any calling number wich comes in with letters like abc or some
like that, get stripped and so that the call gets translated normal, and
send further to the other switch .
Jul 28 13:03:22.031: %SYS-5-CONFIG_I: Configured from console by alp on vty1 (82.xxx.xxx.125)
Jul 28 13:03:32.223: %ISDN-6-CONNECT: Interface Serial0:8 is now connected to unknown unknown
Jul 28 13:03:35.315: %ISDN-6-DISCONNECT: Interface Serial0:16 disconnected from 31104xxxx18 , call lasted 315 seconds
Jul 28 13:03:35.991: The Call Setup Information is :
Call Control Block (CCB) : 0x62CB9E90
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : abc12345
Called Number : 123450031653213197
Number of Media Streams : 1
Jul 28 13:03:35.991: Media Stream 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101
Source IP Address (Media): 212.xx.xx.xx
Source IP Port (Media): 0
Destn IP Address (Media): 192.168.1.21
Destn IP Port (Media): 60632
Jul 28 13:03:35.991: Orig Destn IP Address:Port (Media): 0.0.0.0:0
Source IP Address (Sig ): 212.xx.xx.xx
Destn SIP Req Addr:Port : 82.xxx.xxx.125:0
Destn SIP Resp Addr:Port : 82.xxx.xxx.125:60448
Destination Name : 82.xxx.xxx.125
Disconnect Cause (CC) : 21
Disconnect Cause (SIP) : 403
Please help.
paolo bevilacqua Sat, 07/28/2007 - 07:24
  • Hall of Fame,
    Founding Member
Your taslatio appears wrong, you need "voice translation-rule".
E.g.
voice translation-rule 100
rule 1 /[a-f]/ //
will strip letters in numbers.
paolo bevilacqua Sat, 07/28/2007 - 14:33
  • Hall of Fame,
    Founding Member
Correction, to strip the first set of letters present in a number, rule is correctly written as:
rule 1 /[A-F]+/ //
ikturalo1981 Sat, 07/28/2007 - 15:26
Well I tried that but it didnot accept the command. it accepts only "rule 1 /" and after that does not accept. and I see that I forgot to post in my post the config info:
voice translation-rule 6300
rule 1 /^.*/ /5555556300/
voice translation-rule 63001
rule 1 /^12345/ //
trunkgroup CARR-IN
here is the output of your command :
as530(cfg-translation-rule)#rule 2 /[A-F]+/ //
% Invalid input detected at '^' marker.
as530(cfg-translation-rule)#rule 1 /[A-F]+/ //
paolo bevilacqua Sat, 07/28/2007 - 16:52
  • Hall of Fame,
    Founding Member
Which IOS are you using? it works fine under 12.4(11)XJ4.
paolo bevilacqua Sun, 07/29/2007 - 04:54
  • Hall of Fame,
    Founding Member
Evidently it doesn't handle digits A-F so you will need to upgrade.
