2611 help
Jul 28th, 2007
in another post I am getting this error...
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 32768 Kbytes of main memory
open: file "n" not found
open(): Open Error = -1
loadprog: error - on file open
boot: cannot load "flash:n"
I have done everything that people are saying, format flash xmodem installed new OS ...
Was wondering if anyone would mind working with me and remote in with me to take a look and possible resolve my problem.
balajitvk Sat, 07/28/2007 - 22:45
  • Silver, 250 points or more
When you encouter this problem??? After copying new IOS to flash?? Which mode it is going, rommon mode ?? what is the bootstring you given??
Rgs
rdaggett1 Sun, 07/29/2007 - 05:33
yes this is happening after loading a new IOS, I get that error over and over until i do a break to rommon. at rommon i type boot and it boots.
balajitvk Sun, 07/29/2007 - 09:19
This looks like a mismatch of ios file name in the bootstring and actual one.... Once you booted thro. boot command see the output of show boot and show flash for the spcified boot file name...... Also see the boot sytem flash command in the show run output.....
Accordingly if you corrected this, i hope u can get out of this problem......
Still required, pls. paste the show flash and show run command output.
Rate if it does,
Rgs
rdaggett1 Sun, 07/29/2007 - 12:29
here is the info requested
sh running-config
Current configuration : 621 bytes
version 12.3
hostname Router
boot-start-marker
boot system flash:c2600-io3-mz.123-15a.bin
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
sh flash
Router#sh flash
System flash directory:
File Length Name/status
1 8041044 c2600-io3-mz.123-15a.bin
[8041108 bytes used, 8736104 available, 16777212 total]
16384K bytes of processor board System flash (Read/Write)
Router#
AND SH STARTUP-CONFIG
Using 628 out of 29688 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
They all allok to be the same file .... thanks for you help .. any ideas?
rdaggett1 Sun, 07/29/2007 - 12:45
wondering what private-config and ifIndex is ....
Directory of nvram:/
27 -rw- 621 startup-config
28 ---- 5 private-config
1 -rw- 0 ifIndex-table
balajitvk Sun, 07/29/2007 - 20:47
As you mentioned, it seems to be same.... But your first output shows that it is trying to open flash:n which is bit confusing....
What about your show boot and show version config register output....
Rgs,
rdaggett1 Mon, 07/30/2007 - 05:18
sh ver
IOS (tm) C2600 Software (C2600-IO3-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 21-Jul-05 19:55 by dchih
Image text-base: 0x80008098, data-base: 0x80D545B8
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IO3-M), Version 12.3(15a), RELEASE SOFTWARE (fc2)
Router uptime is 15 hours, 55 minutes
System returned to ROM by reload
System image file is "flash:c2600-io3-mz.123-15a.bin"
cisco 2611 (MPC860) processor (revision 0x202) with 28672K/4096K bytes of memory
Processor board ID JAB031408JN (2668064774)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.16384K bytes of processor board System flash (Read/Write)
I am sorry I am having a hard time finging the sh config register and sh boot commands ....
smothuku Mon, 07/30/2007 - 03:37
Hi ,
what is the config register value (0x2102)?
can you paste show version output of the router.
and type
boot system flash:image.bin in privilege mode and reload the router.
cheers :)
satish
