07-28-2007 09:16 PM - edited 07-03-2021 02:24 PM
I have just received my 4402 controller and a ton of AP's for my wireless implementation. Unfortunately I have not received the 1000BASE-T SFP to hook the thing up to my network. Anyone have any suggestions to getting it going while I wait for my part to come in? I am desperate!
Solved! Go to Solution.
07-29-2007 12:56 AM
Hi Sean,
Sad to say till the time you have the SFP modules you cannot connect these controllers into the network.
If you have any spare one or just sitting idle in any switch you can use the same with your 4402 controller to connect it to the switch network.
Ankur
*Pls rate all helpfull post
07-29-2007 12:56 AM
Hi Sean,
Ankur
