General Pix VPN question
Jul 29th, 2007
I have created a VPN between 2 Cisco 515 pix's. On the ADSM it says the VPN status is 1 IKE tunnel and and 5 IPSec tunnels. Why 5 and not one? We have multiple subnets on one side of the Pix, does it mean if another different subnet travels across the VPN then it will go to 6 IPSec tunnels?
rjwalani Sun, 07/29/2007 - 01:04
  • Cisco Employee,
It depends on the crypto access-list entries.
Ranjana
Jon Marshall Sun, 07/29/2007 - 01:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
For each entry in your crypto access-list that is a potential IPSEC tunnel. So yes in answer to your question if another subnet that isn't already running across the VPN then intitiates a communication through teh VPn tunnel it will indeed crete another IPSEC sa. Actually the SA is uni-directional so 2 sa's are created.
Jon
