How to restrict outbound calls to some destinations nos. only??
ashley9march
I am using cisco 3845 router as voice gateway and running voice serice over that using E1 which is connected to a EPBX.
I am using only 3 dial-peers (2 for VoIP and other one is POTS). I have 20 sites with similar kind of setup and have 2 gatekeepers (primary-secondary) for their call routing.
To make config simple I have used ".T" as destination pattern with session IP of Gatekeepers for dial-peer VoIP in each gateway.
Now the demand of users of site "A" is that they don't want to talk site "B" and "D" because of their some security reasons.
And since I am using gatekeeper and ".T" as destination-pattern I am not able to prevent site site A to call site B and D whose destination nos. are "89" and "950" respectively and I don't want to create 18 different voip dial-peers because with increase in sites in future we will have to update the nos. of dial-peers.
Is there a any solution to that site A can call any site but B and D?
Ashish
Gergely Szabo
I am not quite sure whether it could help you, but I would try to implement COR...
