CCNP HOME LAB
Jul 29th, 2007
Hi, I have just got hold of:
2501 x 1 ios 12.0
2522 1 1 ios 12.0
2900 x 1 ??
3725 x 1 ios 12.2
3620 x 1 ios 12.0
Could someone please tell me if this would be sufficient for a ccnp lab? what else would I need to include? Also I find getting hold of current ios images a maze so if any one could advise it would be much appreciated.
Thank you.
brandonwilson_mog Sun, 07/29/2007 - 10:52
I'm using dynamips and it's fantastic. I can run full feature IOS from the comfort of a single laptop.
Using the dynamips software, I was able to construct a 10 router CCNP lab with frame relay switches, and regular Ethernet switches.
The software is free, and the training is phenominal.
As far as your setup for a lab, it depends on the lab manual you're using. Do you have any lab manuals? Do you have any study books? If not, shoot me an email, and I can help you out.
sivakumar.kvp Tue, 09/04/2007 - 21:33
i had a problem while installing dynamips.can you help me out by sending the procedure of step-by-step guidelines.actually iam planning to take-up the 642-901 exam by the end of this month.consider this is my personal request and revert back on priority.
-shiv.
ukdesignated Thu, 09/06/2007 - 18:34
hi Brandon..i have got Dynamips but need some lab exercises/lab mauals..can you help in any way..would apprciate it
john.jay.franklin Wed, 08/29/2007 - 19:05
I'd suggest 4 more routers at least. One for frame relay such as a 2522. Another 3 for the 'pod' routers as is covered in the CCNP books from Cisco Press.
Here is my ccnp/ccie lab just for a heads up.
6x 3640 (core routers)
2x 3620 (for injecting routes, etc)
1x 2522 (frame relay)
1x 2511 (terminal server)
1x 2501 (injecting routes, etc)
2x 3750G-48P
1x 3750G-24P
1x 3550-24P
unfortunately, the 3750 switches arent mine.. yet! ;)
Hope that helps. :)
