Site to Site VPN with 1841 router and PIX 515
Jul 29th, 2007
I am looking for some information on how to configure a site-to-site vpn connection using the pix 515 and the 1841 router. I have a remote site that I would like to connect to the corporate office via DSL modem. If anyone could give some assistance this would be very helpful.
keyyo0200 Mon, 07/30/2007 - 05:14
Thanks; I need to give a little more information. The 1841 router will be located at the remote site with the DSL modem and the PIX is located at the corporate office. I am looking for some information on configuring the 1841 router for the remote site and configuring the PIX515 to accept the connection from the remote site.
Durga Prasad M.S Mon, 07/30/2007 - 05:22
does your remote 1841 have a static IP or dymanic PPPoE type IP.
if it is static IP the document I have sent you has the detailed steps in that. You can always some back for more help.
Implementing site to site VPN when the remote site is having a dynamic IP is also possible but the security would be weaker as it would dependent only on the pre-shared key.
try to convert your remote site to a DSL with static IP.
durga prasad
keyyo0200 Mon, 07/30/2007 - 07:10
The remote site will have a static IP on the router. I haven't received the document yet.
