07-29-2007 07:56 PM - edited 07-03-2021 02:24 PM
I am having an intermittent problem with clients not receiving DCHP assignments when connecting to a 1310 in non-root (with wireless clients) mode. The 1310 is associating with another 1310 in root mode (with wireless clients) via an infrastructure ssid. Clients are connecting via an ssid in guest mode. The root bridge is wired to a netvanta router which is acting as the DHCP server. Everything is working fine except when I associate with the non-root bridge I can only get an ip address after waiting several minutes. When I watch the debug logs on the nevtana DHCP I can see the request broadcasts come in and I can see that it is sending an offer, but the offer does not seem to make it's way back to the client. If I assign a manual IP address from our subnet to the client computer everything works fine and if I associate with the root bridge via a wireless client it works fine as well. At the moment there are no VLANs, no authentication and just the two SSIDs. Also, everything is on the same subnet. I feel like I've looked at everything, cleared arp caches and can't seem to find this pesky little bug. Any ideas? Thanks
08-04-2007 12:35 PM
Your problem may be related to your having two SSIDs and no VLANs. If using more than one SSID you should really have VLANs defined and attached to the SSIDs. Try removing one SSID and see if that improves matters.
If you need to use multiple SSIDs and VLANs the switch or whatever the bridges are connected to must also support VLANs and have them defined on it.
08-08-2007 06:45 AM
Thanks for the suggestion. I removed one of the SSIDs and still had the same problem. It's only on the non-root ap that I am having DHCP troubles. When connecting to the root AP everything works as expected. The thing that has me confused is that if I wait long enough I eventually do get a DHCP assignment when connecting throught the non-root AP. I don't understand what would cause most, but not all, of the broadcasts not to make it through. Once I have the IP address the connection works flawlessly.
08-08-2007 07:01 AM
In case it's useful here is the config from the root AP. The non-root is pretty much the same except the role is non-root bridge with wireless clients. I'm pretty new at this so there is the chance that I am doing something obviously wrong. Thanks again.
version 12.3
no service pad
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname Cisco_Root
clock timezone GMT -7
clock summer-time T recurring
ip subnet-zero
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 ssid Guest
authentication open
guest-mode
dot11 ssid WLAN
authentication open
infrastructure-ssid
username *** password ***
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Guest
ssid WLAN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root bridge wireless-clients
antenna receive right
antenna transmit right
antenna gain 12
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 192.168.5.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.5.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
sntp server 192.5.41.41
end
