Vlans
Jul 29th, 2007
hi,
I am having 3750 series switch and with this switch 3 servers are connected and these servers are in different IP range. With this 3750 switch 3 ring networks are also connected these ring networks contains clients with are accessing servers. These clients are also in the same IP range as of their corresponding server IP range. All these server and clients are in VLAn1. now i have to separte these rings in different vlans.
ankbhasi Sun, 07/29/2007 - 23:10
Hi Friend,
If you want to seperate them in different vlan then do you also want clients from different vlans accessing servers in different vlan or simply clients in one vlan should access servers in their vlan?
If you want clients in same vlan to access servers ins ame vlan then you do not need any inter vlan routing but if you want servers from different vlans should be accessible from clients in different vlan then you need inter vlan routing.
First create vlans at layer 2 on your switch
Switch(config)#vlan
Perform the same commands for number of vlans which you want on your switch.
Once you have created these vlans at layer 2 check via "sh vlan" command. Once done you can create logical interface for those vlans for routing purpose.
Switch(config)#interface vlan
Switch(config-if)#ip address x.x.x.x x.x.x.x
Perform the same commands for all vlans you want routing to be enabled and once done assign your clients in respective vlans with gateway ip address what you configured for your logical interfaces.
Check this links to create vlans on 3750 switch
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12237se/scg/swvlan.htm
For inter vlan routing on 3750 switch have a look at this link
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Ankur
*Pls rate all helpfull post
shahryarmunir Sun, 07/29/2007 - 23:19
I want all the servers to remain in vlan1 and ring1 members in vlan 2,ring 2 members in vlan 3.
Tommer Catlin Mon, 08/13/2007 - 19:04
Hi Ankur!
So here is where I am confused. After my switch is setup (3560) I add my VLANS
VLAN 100 Data
Vlan 200 Voice
Each port gets the correct configuration (mode access, etc)
But I can figure out how to enabling routing between the two VLANS. Is it the VLAN database or something else I need to enable? I can not get this to work.
Thanks!
mahmoodmkl Sun, 07/29/2007 - 23:10
U need to first create 3 vlans in ur 3750,then assign the 3 servers in different vlans as per u r requirement.
As far connecting the ring network assing then links connecting to this switch in differnet vlans.
Then u need to create SVI's on 3750 for the three vlans in order enable inter-vlan routing.
Mahmood
