cisco RSP2 (R4700) question
Jul 30th, 2007
Hello Cisco:
We have a device that I telneted to which is the loopback address. The weird thing is that this device has all the physical interface as down but does have a bunch of vlan inteface that are up. I assume it must be a a route-processor I'm connected to. How do verify this?
Here is the show version:
pdum01r05>show version
IOS (tm) C5RSM Software (C5RSM-JSV-M), Version 12.0(15a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 08-Feb-02 04:36 by dchih
Image text-base: 0x60010930, data-base: 0x60DA6000
ROM: System Bootstrap, Version 11.2(17523) [mohsen 102], INTERIM SOFTWARE
BOOTFLASH: C5RSM Software (C5RSM-DSV-M), Version 11.2(13)P, RELEASE SOFTWARE (fc1)
spdum01r05 uptime is 5 weeks, 1 day, 1 hour, 31 minutes
System restarted by reload at 02:38:31 EST Sun Jun 24 2007
System image file is "slot0:c5rsm-jsv-mz.120-15a.bin"
cisco RSP2 (R4700) processor with 32768K/2072K bytes of memory.
R4700 processor, Implementation 33, Revision 1.0
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software.
TN3270 Emulation software.
1 C5IP controller (16 Vlan).
1 VIP2 controller (4 Serial).
16 Virtual Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
Here is the I.P interface brief:
spdum01r05>show ip interface brief
Vlan0 YES manual up up
Vlan1 YES NVRAM up up
Vlan10 YES NVRAM up up
Vlan11 YES NVRAM up up
Vlan12 YES NVRAM up up
Vlan40 YES NVRAM up up
Vlan41 YES NVRAM up up
Vlan100 YES NVRAM up up
Vlan101 YES NVRAM up up
Vlan102 YES NVRAM up up
Vlan103 YES NVRAM up up
Vlan104 YES NVRAM up up
Vlan150 YES NVRAM up up
Vlan154 YES NVRAM up up
Vlan156 YES NVRAM up up
Vlan157 YES NVRAM up up
Serial0/0 unassigned YES unset administratively down down
Serial0/1 unassigned YES unset administratively down down
Serial0/2 unassigned YES unset administratively down down
Serial0/3 unassigned YES unset administratively down down
Loopback0 YES NVRAM up up
Actually, I found the switch that has the router module. thx
Overall Rating: 5 (1 ratings)
mohammedmahmoud Mon, 07/30/2007 - 00:27
Yes, this is Catalyst 5000 Route Switch Module (RSM), you can verify this from "C5RSM Software" and from the IOS name "c5rsm-jsv-mz.120-15a.bin".
Mohammed Mahmoud.
