NAT table
Answered Question
Jul 30th, 2007
hello
there is that nat table (from attached file) but i cant figure out what these last 4 entries means. can anybody illuminate me pls.
thanks
Correct Answer by mohammedmahmoud about 9 years 7 months ago
hi,
In order the 4 entries are, Inside global - Inside local - Outside local - Outside global, please refer to the following link for more details:
http://www.cisco.com/warp/public/556/8.html
Inside local address - The IP address assigned to a host on the inside network. This is the address configured as a parameter of the computer OS or received via dynamic address allocation protocols such as DHCP. The address is likely not a legitimate IP address assigned by the Network Information Center (NIC) or service provider.
Inside global address - A legitimate IP address assigned by the NIC or service provider that represents one or more inside local IP addresses to the outside world.
Outside local address - The IP address of an outside host as it appears to the inside network. Not necessarily a legitimate address, it is allocated from an address space routable on the inside.
Outside global address - The IP address assigned to a host on the outside network by the host owner. The address is allocated from a globally routable address or network space.
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (2 ratings)
Correct Answer
mohammedmahmoud Mon, 07/30/2007 - 00:34
hi,
HTH,
Mohammed Mahmoud.
