Cisco switch and high CPU and memory.
johnleeee
Hi all,
I have a question related to the commands
sh processes memory and sh processes cpu.
We have WS-C2924-XL-EN and when I write those commands I see that memory is used over 85 % and cpu is about 50 %.
Over there si a lot of info. How I resolve what is really eating those resources?
BR
JL
5 Replies 5
manmeetmarwah
Hi John,
You have to look at the process which is eating up the maximum memory & CPU. For eg:
sh proc memory
Total: 171242656, Used: 31009484, Free: 140233172
PID TTY Allocated Freed Holding Getbufs Retbufs Process
161 0 188 0 7048 0 0 DHCPD Database
162 0 0 0 17904 0 0 IP-EIGRP Router
163 0 314623268 309146300 5524812 0 0 IP-EIGRP: PDM
164 0 0 0 17904 0 0 IP-EIGRP Router
165 0 104796788 104020336 774552 0 0 IP-EIGRP: PDM
166 0 8128008 8128008 6852 0 0 IP-EIGRP: HELLO
167 0 8125036 8125036 6852 0 0 IP-EIGRP: HELLO
Just have a look at the values under HOLDING field. In this case we can see that EIGRP process is holding the maximum memory. Similarly you can see for process in the CPU command.
Manmeet
*Pls rate if helpful
thanks for answer. Iv found other switch which has higher memory load. *Init* process eats up the most resources. What do you think about it?
BR
jl
michal.grzelak
Hi John,
Try using - "sh processes cpu | exclude 0.00%". Then You will see which process loads Your switch. From expirience I know that on Cat2900, there is process "Calhoun LED Proc" which is taking about 16% of CPU and that is normal for this switch series.
Regards:
Michal
glen.grant
Doesn't sound that bad , a little busy . 2924's will run 30% without anyone doing anything which is normal . If you are worried about it follow this http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a0080094e78.shtml
Hi all,
Thanks for help..Iv read document.
When I put down CLI command I see next.
CPU utilization for five seconds: 28%/8%; one minute: 28%; five minutes: 28%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
14 1162139 857737 1354 0.30% 0.30% 0.31% 0 Per-Second Jobs
18 5719044 18997303 301 1.22% 1.15% 1.61% 0 LED Control Proc
20 62365866 34759412 1794 12.59% 11.17% 11.08% 0 Port Status Proc
23 1637051 5888677 277 0.30% 0.33% 0.30% 0 GDS Frame Ager
30 4909894 5562186 882 0.61% 0.63% 0.62% 0 Broadcast Storm
35 3524459 1362600 2586 0.02% 0.83% 0.78% 0 Enet Aging
BR
jl
