assigning ip address
Jul 30th, 2007
a funny thing happned ,when i config a ip address on a interface.the system log in last line suggest that is illegal address.
i know is a network address and can't be used like that.can anyone tell me,why and can be assigned to the interface.
R1(config-if)# ip address
R1(config-if)#ip address
Bad mask 0xFFFFFFC4 for address
Jon Marshall Mon, 07/30/2007 - 00:56
Unless there is a typo it is your subnet mask that is giving the error message ie. should be is not a network address, that would be
ankbhasi Mon, 07/30/2007 - 01:03
Hi Friend,
IP address and are valid address because their subnet range start from - out of which is the first address and for second ip address subnet range is - out of which is again the first address.
But you last address with mask is wrong because is not a valid mask and if you use with mask like you used for other it should work fine.
*Pls rate all helpfull post
