Switch Lose Port configuration after reboot
Jul 30th, 2007
I have cat 4000 with IOS 12.2(25)EWA7 software, I'm facing a strange issue when I reload the switch ,the ports lose the VLAN configuration and goes back to the default Vlan.other configuration remains OK.
the configuration register is 0xA101 , is that OK.
Any one face this issue.
ankbhasi Mon, 07/30/2007 - 01:06
Hi Friend,
The config register value is wrong and should be changed to 0x2102. Try that then issue wr mem and reload the switch and see if it looses the config again.
*Pls rate all helpfull post
Ali Koussan Wed, 08/01/2007 - 00:47
Hi ,
Thanks for the help , but if I use 0x2102 , I should use the boot system command , or else the switch will boot in rommon mode, right?
I have only one IOS in switch bootflash.
glen.grant Wed, 08/01/2007 - 03:36
Don't believe that is true , you can use a boot statement and it will use it but if there is no boot statement it will just use the first image it finds in bootflash .
Ali Koussan Sun, 08/05/2007 - 02:25
I have changed the config reg but when I reload the switch it goes to Rommon mode , and I had to issue the command boot after that the switch boot normally..
I check the bootvar but nothing is showing there.
what do you think?
sundar.palaniappan Sun, 08/05/2007 - 06:09
I have seen some switches behave this way. Set the config register to 0x2102, configure the 'boot system flash' command and try.
Ali Koussan Wed, 08/08/2007 - 00:37
Hi ,
I set the config register to 0x2102 , and I configured the boot system flash , but still the switch is going to rommon mode when reset.
Notice that in my switch the IOS is on bootflash , not flash , so when I typed the command boot system , I dont have option bootflash , it is only flash , so the command I used is :
boot system flash cat4000-i9s-mz.122-25.EWA7.bin
What do you think?
Ali Koussan Fri, 08/10/2007 - 22:22
is the below show bootvarv normal ?
BB#sh bootvar
BOOT variable = :,1;,1;cat4000-i9s-mz.122-25.EWA7.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
glen.grant Sat, 08/11/2007 - 02:27
Use "boot system flash bootflash:cat4000-i9s-mz.122-25.EWA7.bin . Then you have to do a write mem before it will show up in the show bootvar command.
