07-30-2007 02:15 AM
I am having problem in calling BRI from PRI. I am getting below message while debugging. Also note that calling from BRI to PRI is successful.
Mar 2 23:38:22: ISDN BR0/0 Q931: RX <- SETUP pd = 8 callref = 0x04
Sending Complete
Bearer Capability i = 0x8890
Standard = CCITT
Transer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x2183, '1726601501'
Plan:ISDN, Type:National
*Mar 2 23:38:22: ISDN BR0/0:1: Incoming call rejected, unbindable
*Mar 2 23:38:22: ISDN BR0/0 **ERROR**: host_incoming_call: DIALER ERROR 0x1: b channel 0, call id 0x15E
*Mar 2 23:38:22: ISDN BR0/0 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x84
Cause i = 0x8095 - Call rejected
Pls help me.
Anis
9229109694
07-30-2007 02:30 AM
Please send BRI router config and what router / card it is.
07-30-2007 02:36 AM
07-30-2007 03:53 AM
Hi ,
Pease configure username and password on both routers ...in privileged mode.
cheers :)
satish
07-30-2007 03:59 AM
Dear Satish,
Can u pls give me an example for this config.
As Enable Secret is already configured on both the Routers.
Anis
07-30-2007 05:17 AM
Yes you have to configure "ppp chap username" under dialer interface.
07-31-2007 01:08 PM
PPP Multilink is not been enabled...
If it is enable than use rotary group command.
" EITHER " command.
Dharmesh Purohit
07-31-2007 08:02 PM
Dear Dharmesh,
Can u pls explain where to enable PPP Multilink.
Dear p.bevilacqua ,
I did what u told (configure "ppp chap username" under dialer interface), but the problem is same.
Anis
