mike_perish Thu, 08/02/2007 - 05:36
I have also used these steps. I see the url for the original Cisco article that I got the informtion from is outdated.
From the boot prompt:
ether_init
flash_init
set IP_ADDR 10.10.252.20
set NETMASK 255.255.252.0
set DEFAULT_ROUTER 10.10.252.1
tftp_init
tar -xtract tftp://10.10.252.14/c1200-k9w7-tar.123-7.JA2.tar flash:
(The final tar -xtract command should be on one line.)
Alejandro Corte... Thu, 08/02/2007 - 06:14
  • Silver, 250 points or more
ok just follow these steps is an easy way to upload an IOS image to cisco Access points:
http://cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html#wp161272
Iknow that you are not talking about LWAPP but this process will help you.
Here the steps that are in the link.
Using a TFTP Server to Return to a Previous Release
Note This section does not apply to Cisco C3201WMIC and Cisco C3201LAP.
Follow these steps to revert from LWAPP mode to autonomous mode by loading a Cisco IOS release using a TFTP server:
Step 1 The static IP address of the PC on which your TFTP server software runs should be between 10.0.0.2 and 10.0.0.30.
Step 2 Make sure that the PC contains the access point image file (such as c1200-k9w7-tar.122-15.JA.tar for a 1200 series access point) in the TFTP server folder and that the TFTP server is activated.
Step 3 Rename the access point image file in the TFTP server folder to c1200-k9w7-tar.default for a 1200 series access point, c1130-k9w7-tar.default for an 1130 series access point, and c1240-k9w7-tar.default for a 1240 series access point.
Step 4 Connect the PC to the access point using a Category 5 (CAT5) Ethernet cable.
Step 5 Disconnect power from the access point.
Step 6 Press and hold MODE while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds) and then release.
Step 8 Wait until the access point reboots, as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, reconfigure it using the GUI or the CLI
I hope this help you
