Connection plar opx issue
Jul 30th, 2007
Hello friends,
I have a callmanager express 4.1 and it has been working fine until recently. Below is the except of the configuration.
voice-port 0/0/1
connection plar opx 8533
ephone-dn 22
number 4935
ephone-dn 23
number 8533
ephone-dn 24
number 3333
ephone-dn 25
number 3332
ephone 1
device-security-mode none
description Master
after-hour exempt
mac-address ABCD.EFGH.IJKL
type 7971
button 1:22 2:23 2:24
ephone 2
description Boss
after-hour exempt
mac-address XXXX.XXXX.XXXX
type CIPC
button 1:25
When a call comes on the voice-port 0/0/1, I want it to be forwarded to the correct phone+button. This was working fine from but now, it does not go through. If I change the "connection plar opx" to any number say, 4935 or even 3332, it works fine without any problems.
Please help.
Paolo Bevilacqua Mon, 07/30/2007 - 03:43
perhaps some data structure got trashed, try reloading the router. Since you are in there, upgrade to XJ4 that is the lastest with many bug fixes.
jkofosu Mon, 07/30/2007 - 04:02
Is there much difference between the XJ2 and XJ4?
I am currently running the XJ2.
Paolo Bevilacqua Mon, 07/30/2007 - 04:12
Yes there is. Like 50 voice-specific bugs fixed. And some are quite ugly ones. Check the release notes.
