GTS and WFQ
Jul 30th, 2007
I'm using GTS (Generic Traffic Shaping) on interface (I would like to limite trafic to 2MBps), and I would like to configure WFQ, which is the default algorithm working with GTS. But I can't succeed to configure the size of the queue. Do you know how can I do?
As I know the WFQ cannot be configured just can be enabled or disabled by fair-queue (or something like that) command on per interface basis. This flow based qos technique classifies the traffic and you will have a queue for each flow and the scheduler will service each queue by some algorithm. You don't have the option to influence it.
Hope it helps, rate if does
Krisztian
jwdoherty Mon, 07/30/2007 - 06:41
My experience is GTS uses WFQ within the shaper itself. Don't believe you have any control over its WFQ settings. Something you might need to check with TAC.
