AS5400 / cc terminal problem when speaking to a server
Hi there,
When I dial from cc terminal into my as5400 box, it tries to speak to the authentication server which is on the LAN. However, the connection is rejected by the server due to unexpected error.
I've managed to capture the traffic using ethereal, then had a chat with our developers. They identify the problem saying:
there is something wrong with the router as it sends useless characters (lots of 0x91 0x11 bytes) and sends them one by one instead of a whole frame.
Indeed, all the frames sent by as5400 are 60bytes long - why?
Is it possible to debug the as5400 to analyse incoming frames from the terminal and see how they're transformed before being sent to the server?
Paul
Paolo Bevilacqua Mon, 07/30/2007 - 13:53
What protocol do they "speak", IP ?
What is CC ?
The minimum legal length for ethernet is 60 bytes, that is why you see that.
Paolo Bevilacqua Tue, 07/31/2007 - 00:18
What exact protocol ? How is the router configured ? It will normally send all the characters received by the CC terminal.
Here is the config...
Building configuration...
Current configuration : 4381 bytes
! No configuration change since last restart
version 12.4
service tcp-keepalives-out
service timestamps log datetime localtime show-timezone
boot-start-marker
no boot startup-test
boot-end-marker
logging buffered 16000 debugging
resource-pool disable
no aaa new-model
clock timezone gmt 0
clock summer-time IRL recurring last Sun Mar 2:00 last Sun Oct 2:00
clock calendar-valid
spe default-firmware spe-firmware-1
no ip subnet-zero
no ip source-route
ip cef
no ip domain lookup
ip host SERVER 10.2.10.100
no ip bootp server
isdn switch-type primary-net5
modemcap entry PP4:MSC=&fd0
modemcap entry 5100C:MSC=&F&D2S22=0S23=0S24=1S21=3S0=1
controller E1 7/0
pri-group timeslots 1-31
controller E1 7/1
controller E1 7/2
controller E1 7/3
interface GigabitEthernet0/0
ip address 10.2.10.6 255.255.255.0
no ip proxy-arp
ip ospf hello-interval 3
ip ospf dead-interval 10
ip ospf retransmit-interval 2
duplex full
speed 100
negotiation auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
negotiation auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial7/0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
interface Serial7/1:15
no ip address
encapsulation hdlc
interface Serial7/2:15
no ip address
encapsulation hdlc
interface Serial7/3:15
no ip address
encapsulation hdlc
interface Group-Async0
no ip address
encapsulation slip
no group-range
interface Group-Async1
no ip address
encapsulation ppp
async mode interactive
no peer default ip address
ppp authentication chap radius-ppp
group-range 1/00 1/107
ip tacacs source-interface Loopback0
no ip http server
control-plane
voice-port 7/0:D
voice-port 7/1:D
voice-port 7/2:D
voice-port 7/3:D
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
line 1/00 1/107
no motd-banner
no exec-banner
exec-timeout 0 0
no flush-at-activation
script modem-off-hook offhook
no vacant-message
modem InOut
modem autoconfigure type 5100C
autocommand connect SERVER 2600 /stream
no activation-character
exec-character-bits 8
special-character-bits 8
no history
no editing
transport preferred none
transport input all
transport output lat pad telnet rlogin udptn v120 lapb-ta
escape-character NONE
no ip tcp input-coalesce-threshold
scheduler allocate 10000 400
end
Paolo Bevilacqua Tue, 07/31/2007 - 05:20
You have /stream, means the router is sending what is receiving. Check again the captured frame and the TCP payload length (not total frame length). Is error correction enable and working with the CC modem ?
Paolo Bevilacqua Tue, 07/31/2007 - 06:51
You can debug what the modem sends and receive with "debug modem traffic". be aware that if you have many calls it can produce a lot of traffic so try to limit and log to buffer.
This way it should be possible to prove that the bytes you mentioned above are being received verbatim from the CC modem.
