Configuring a terminal server - problem
Jul 30th, 2007
I started configuring a 2511 as a terminal server. I have a problem with the following command:
line con 0
logging synchronous
login
transport input none
I can't give this command, because I can't give the command, "transport input' because in my router I don't have 'input option. Instead what I have is 'output' option. Then if I'm to give this command I will have to say, 'transport output none'
I have two octal cables connected to the 2511 (which is the terminal server I'm configuring) and the RJ45 ends to the other routers.
I have another problem in the following command as well:
line 1 4
session-timeout 20
no exec
exec-timeout 0 0
no flush-at-activation
logging synchronous
modem InOut
transport input all
line 5 16
session-timeout 20
no exec
exec-timeout 0 0
modem InOut
transport input all
when I give these command, I get a message saying that, 'Line 2 does not supprt modem control' and 'Line 5 does not support modem control'
However after finish configuring, when I telnet to the terminal I am suppose to asked for a username, because I give the following command:
username p1r1 nopassword
username p1r1 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2001
But, may be because I get those error messages I do not get the screen, which asks me the username. When I telnet to the terminal server, I don't get anything on the screen and screen turns off in a few seconds, as if I'm trying to telnet without configuring a password.
I have used the same configuration at office. Then it works just fine.
I am very concerned about the two error messages I get and why I get them. Can you please explain why and give me a solution to over come this situation and to make it up and running.
Thanks a lot in advance!
Overall Rating: 4 (1 ratings)
mohammedmahmoud Mon, 07/30/2007 - 05:53
Please follow the following (and note that you don't need anything mandatory under the consoles)
under the serial interface (If A/S):
--> physical-layer async
--> async mode interactive
under the async TTY line(s):
--> transport input telnet
--> stopbits 1
NOTE: "no exec" under the lines - Unwanted signals from the attached device do not launch. An EXEC session ensures that the line never becomes unavailable due to a rogue EXEC process.
and connect the cables to the console of your devices using the Octal male DB-68 (SCSI II) connector (CAB-OCTAL-ASYNC), since the CAB-OCTAL-ASYNC cable is itself rolled, you can connect each cable directly to the console ports of devices with the RJ-45 interfaces.
Issue this command to establish a reverse Telnet connection from your terminal server - console server - comm server:
telnet x.x.x.x 2yyy or [2000+yyy]
The x.x.x.x represents the IP address of any up/up interface on the Cisco router (recommended to be a Loopback) and yyy is the line number to which you want to connect (5 = 005). If you have already configured the TTY line, you can issue the telnet command from anywhere on the network that can ping the x.x.x.x interface.
To get yyy do "show line" and then add the number to 2000 thats how you get the 2yyy number (port number) to use to reverse telnet, ex: for line 5 use 2005.
Each line corresponds to an RJ-45 cable and thus to one of your devices.
To disconnect, hit Ctrl-Shift-6 and then x to get back to the router prompt and then type in disconnect to close the connection.
To add an Alias for each of your devices:
ip host
ex: ip host 3600-2 2013 172.21.1.1
HTH,
Mohammed Mahmoud.
omal Mon, 07/30/2007 - 09:57
Hi Mahmoud
Many thank for your detailed clarification.
I can't give the command 'no exec'. The moment I give that command I don't see anything when I telnet. But without 'no exec' command under line 1 16 I get the option to enter the username. I configured it like this:
username r1 nopassword
username r1 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2001
Oh and by the way, I telnet from the LAN. I don't configure serial interfaces. I go in through ethernet port.
Now the problem is, when I telnet I can enter the username. Then I enter the username as 'r1'. Then it says, 'Trying 10.0.0.101 ... 2001 open'
but it never logs in to the other router via console port. I use the same setup at a different place and it works there.
Any advice???????
Many thanks in advance.
mohammedmahmoud Mon, 07/30/2007 - 13:10
hi,
I think that the problem is in the "resume 10.0.0.101 /connect telnet 10.0.0.101 2001".
Can you please post all your routers relevant configuration.
HTH,
Mohammed Mahmoud.
omal Wed, 08/01/2007 - 08:52
Hi Mahmoud
Below is the configuration. And you know something I tried it with another 2511 router. It worked.
My main problem in the router that it doesn't work, is that in that router the I get the following two errors.
error (1)
in line console 0.
(config)#line con 0
(config-line)#tranport ?
output
preferred
But I should get an option called 'input' in here. I don't get that. Do you know why?
error (2)
(config)#line 1 4
(config-line)#modem InOut
error: Line 2 does not support modem control
Why I get an error like that. I don't get it in any other routers. Is it a hardware problem?
I think mainly due to these two errors that I'm getting I can't properly configure the terminal server (router). Do I have to activate something to be able to issue those two commends or can it be a hardware error?
Please see below for my complete configuration.
Many thanks mahmoud!
2511#sh run
Building configuration...
Current configuration : 3195 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname 2511
logging rate-limit console 10 except errors
enable password cisco
username Tim privilege 15 password 0 cisco
username r2 nopassword
username r2 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2002
username r3 nopassword
username r3 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2003
username r4 nopassword
username r4 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2004
username r5 nopassword
username r5 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2005
username r6 nopassword
username r6 autocommand resume 10.0.0.101 /connect telnet 10.0.0.101 2006
ip subnet-zero
no ip finger
no ip domain-lookup
no ip dhcp-client network-discovery
interface Loopback1
ip address 10.0.0.101 255.255.255.0
interface ethernet 0
ip address 192.168.1.254 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip kerberos source-interface any
ip classless
no ip http server
line con 0
logging synchronous
login
line 1 4
session-timeout 20
no exec
exec-timeout 0 0
logging synchronous
modem InOut
transport input all
line 5 16
session-timeout 20
no exec
exec-timeout 0 0
modem InOut
transport input all
line aux 0
password cisco
logging synchronous
login
line vty 0 4
exec-timeout 20 0
logging synchronous
login local
line vty 5 15
exec-timeout 20 0
logging synchronous
login local
end
