CRS SDK development
Jul 30th, 2007
I want to develop in CRS SDK custom node which will hanlde voice input like standard nodes.
Question is:
How I can get access to a voice objects from custom node?
Gergely Szabo Mon, 07/30/2007 - 06:47
you should consult the CRS SDK documentation, but watch out, there is not too much in there.
Those 'custom nodes' are customised steps ~ and all steps are Java beans in which you should be access the public objects.
vladimirbanker_2 Mon, 07/30/2007 - 06:50
May be somebody know which public objects can provide me access to voice/rtp to manipilate it?
Gergely Szabo Mon, 07/30/2007 - 06:53
Actually: what are you trying to achieve? There might be an easier way to do it...
Gergely Szabo Mon, 07/30/2007 - 22:26
Hello again,
actually, what you need is JTAPI - you may want to instruct CallManager to provide you with the objects thru JTAPI calls using IVR.
I am not a programmer, but if I were, I would definitely go that way...
And I would not bother creating a custom subsystem - it is not worth the pain. Use RMI when possible...
vladimirbanker_2 Tue, 07/31/2007 - 03:41
JTapi/TAPI can provide me CallControl/event handling.
It is not possible manage media via JTapi.
Or exist set API for media control?
