Problem connecting to a website though ASA
Jul 30th, 2007
I have an ASA and connection to the internet. I'm currently having problems with connectivity to a server which dishes out WMP DRM licenses. I read the 'known problem' relating to the MSS but this doesn't seem to be the problem as the values stated in the SYN and SYN-ACK's via an Etheral capture on my laptop look OK. The server responds after the HTTP GET with a HTTP 500 error. I've tried the same site/license HTTP string on my home broadband with a PIX and all works a treat. Any suggestions or next steps? Cheers
CSCO10631105 Tue, 07/31/2007 - 00:19
Update:
During a succesful conection to the server an Etheral capture shows that the server responded to the HTTP get with a "(TCP previous segment lost), continuation or non HTTP traffic" which contained half of my HTTP web address string. Then a duplictae ACK is sent from the client, then the server responds with a TCP re-transmission of the 'HTTP found' command. This happen EVERY time, I guess this is the source of the problem as the ASA must not like this duplication/retransmission.
Can anyone help!?
Cheers
CSCO10631105 Tue, 07/31/2007 - 07:39
Is there anyone who can help?
I've been reading this in the documentation......
Set the maximum number of out-of-order packets that can be queued for a TCP connection:
hostname(config-tcp-map)# queue-limit pkt_num
Where pkt_num specifies the maximum number of out-of-order packets. The range is 0 to 250 and the default is 0
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/protect.html
The default for a PIX OS 6 is 3 - could this be why the ASA is discarding the out of sequence packets?
You can see if the o-o-o packets are causing your issue by looking at the 'show asp drop' command. There is a counter called Out of order packet buffer full. If this counter increments quickly, you need to increase the number of buffers. Here is an explanation on how to change the buffer size:
1) Define an access-list for interesting traffic:
access-list tcp-queue-limit extended permit tcp any any eq 80
access-list tcp-queue-limit extended permit tcp any eq 80 any
access-list tcp-queue-limit extended permit tcp any any eq 443
access-list tcp-queue-limit extended permit tcp any eq 443 any
This only defines it for port 80 and 443 traffic.
2) Define your tcp-map:
tcp-map queue-limit-map
queue-limit 6
3) Define a class map:
class-map tcp-queue-limit
match access-list tcp-queue-limit
4) now match everything up in your policy map that is/will be applied globally:
policy-map global_policy
class tcp-queue-limit
set connection advanced-options queue-limit-map
Note: this can only be done on an ASA not a PIX
******** Please Rate *****************
Jay
CSCO10631105 Tue, 07/31/2007 - 08:15
Cheers but I dont see any TCP errors when I look at the 'sh asp drop' output.
Could it be an MTU issue?
