IP Phone services - Rotate Image?
Jul 30th, 2007
I've been working with one of my web guys and we can't seem to figure this out. I have three images that I want to rotate thru on a 7960 phone via the idle url. I'm using the code below to pull up an image. According to the Cisco documents, I should be able to add response.addheader ("Refresh", "3", URL) and it should go to the next logo but it's not. How do I get this to work?
Set mydoc = Server.CreateObject("Microsoft.XMLDOM")
mydoc.async = False
mydoc.load(Server.MapPath("logo.xml"))
Response.ContentType = "text/XML"
Response.write mydoc.xml
Jorge.Severino Mon, 07/30/2007 - 09:01
Hi scott,
I think when you refresh, your script doesn't know that he have to send another image to the phone..
Maybe you can try something like:
Select Case (ID_IMG)
Case 1:
response.addheader ("Refresh", "3", URL+"?ID_IMG=2")
mydoc.load(Server.MapPath("logo1.xml"))
Case 2:
response.addheader ("Refresh", "3", URL+"?ID_IMG=0")
mydoc.load(Server.MapPath("logo2.xml"))
Case else:
response.addheader ("Refresh", "3", URL+"?ID_IMG=1")
End Select
I don't know if this work, is just an idea..
Greatings.
Jorge
scott.weismann@... Mon, 07/30/2007 - 10:54
Well, I added that to my script and the phone is now displaying an error that refers to line 5 (which is the beginning of what I added. See modified script below:
mydoc.async = False
Case 1:
mydoc.load(Server.MapPath("sonly.xml"))
Case 2:
Case else:
mydoc.load(Server.MapPath("text.xml"))
End Select
Any other ideas?
Jorge.Severino Mon, 07/30/2007 - 11:10
The Code is just for reference.. an idea..
You don't have to put comiles (") and '...'.
I'm just suggest you to use SELECT CASE statement on your script..
Is not a "copy/paste" code.
Jorge
scott.weismann@... Mon, 07/30/2007 - 18:36
Ah. Sorry, I'm just not the best yet at this coding. Not sure how to use the SELECT CASE statement.
rameshbalajiv Fri, 09/12/2008 - 09:52
Scott:
Please let me know how you have accomplished this using ASP.
Thanking You
Ramesh Vasudevan
msabir Fri, 09/12/2008 - 20:06
I have an example code, but it is in JSP and it is used by PhoneTop Messenger's Idle URL feature, which allows admins to create an Idle URL service with rotating images and/or text.
scott.weismann@... Mon, 09/15/2008 - 05:53
I've attached the files that I use to accomplish this. You will need to create the image XML files and then set one of the ASP files as the Idle Url on the phones that you want to use it. Mine rotates between 3 images but you can have it be more or less if you like.
mnour401917_2 Sun, 11/09/2008 - 21:33
Scott,
Any chance that you would let me know, how to convert an Image to XML format.
Cheers
