Transcoders, a question
Answered Question
Jul 30th, 2007
I have recently come across some problems between calmanagers using intercluster trunks. Basically it looks like i dont have transcoder resources.
The documentation seems to indicate i need hardware resurces and mentions catalyst 6000 and 4000 blades, problem is i dont have these. Can is use the DSP resources on my routers and if so how do i do it?
colin
Correct Answer by dgahm about 9 years 10 months ago
Colin,
Yes, you can configure DSPs in a router as a DSP farm with transcoding and conference bridging. What model router, and what DSPs do you have available?
Here is a good doc to get you started:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a008084fe1f.shtml
Please rate helpful posts.
Dave
Overall Rating: 5 (1 ratings)
Correct Answer
dgahm Mon, 07/30/2007 - 08:51
  • Blue, 1500 points or more
Colin,
Dave
ReadersUK Tue, 07/31/2007 - 07:35
Hi Dave
Thanks for that, the document did the trick.
colin
