IPM problem with shadow router management vlan and services vlan
Jul 30th, 2007
Hi everybody!
Im trying to config a shadow router that has 2 vlan int one is for managemt and the other for services.
Cisco Works server only sees the management interface of this shadow router.
On the other end i have a cisco device with rtr responder enabled on the services vlan, so shadow router and this device see each other on this vlan.
In the shadow router i know i can configure the source address.
Is there a way i can configure the end device as a target that has rtr responder enabled even if i cant reach it from the Cisco Works Server?
thanks in advance.
