hiding an extension in CCM 4.1 from public calls
wdrootz Fri, 08/03/2007 - 05:59
  • Bronze, 100 points or more
Manipulate the number in Line text, in phone config page.
sarmentrout.qwest77 Fri, 08/03/2007 - 06:51
Jose,
I am a little confused as to what you are really trying to accomplish. Are you trying to have people see your number on the directory but not allow people to walk up to the phone and see what your number is? If so, the other post is correct, just change it on the line configuration page of the phone, under the line text label section. If you don't want people to be able to call it from the public (externally), then you will need to change partitions. If you need other information, please let me know...
Scott
The user would like to screen the incoming calls and forward them to the appropriate extensions, but when he receives an outside call, his extension is listed in the directory and so that's what he would like to remove. Is it possible to remove it, but keep it for internal users? That's so confusing!
