Jul 30th, 2007
Hello, I have a issue with the conection to VPN, sometimes it doesn?t work only show the client the follow message Secure VPN Connection terminated locally by the client. Reason 412: The remote peer is no longer responding, the PC?s are using the cisco client 4.0.3.
The topology is very simple, we have a speedstream 5200 conected to internet and behind it, we have a switch cisco 3550 that give the LAN service (DHCP server etc) I attach the log file from the client
Could you help to resolve this problem
Thanks and best regards
Hieu Cao Mon, 07/30/2007 - 11:55
Take a look at the memory resource on your VPN box. Low memory resource can cause the disconnection error that you're experiencing. Also, try rebooting the VPN box.
