remove VPN client 5 from Vista
Jul 30th, 2007
I did try to install latest VPN client buy it total lucked my Vista pc after 40%. Need to do hard reset of the pc and now I cannot install or remove application.
Don?t find Cisco under add/remove program
Get error 28000 when run exe file how tell to uninstall previous version
What to do?
thomas.chen Fri, 08/03/2007 - 09:43
You can install the VPN Client on your system through either of two different applications: InstallShield and Microsoft Windows Installer (MSI). Both applications use installation wizards to walk you through the installation. Installing the VPN Client through InstallShield includes an Uninstall icon in the program group; MSI does not. In the latter case, to manually remove VPN Client applications, you can use the Microsoft Add/Remove Programs utility
