ACS Merge
Jul 30th, 2007
I have two ACS servers. One running 3.1 and the other is running 3.2. My plan is to decommission the 3.1 however, I would like to move the users from the old server to the new one.
Is there a way to do it? I will need to migrate the user list and their passwords and then import them in the ACS 3.2 without destroying the current users in the 3.2.
Waiting for any feedback,
m-haddad Mon, 07/30/2007 - 11:28
Thanks for the reply but the 3.2 is an SE. The SE has no CSUTILS utility. Also, do the import and export preserve the user's passwords?
Waiting for your feedback,
m-haddad Mon, 07/30/2007 - 13:22
So does that mean I export the users from ACS for Windows using CSEUTIL and then import them to the ACSse using the RDBMS?
Would that work?
m-haddad Wed, 08/01/2007 - 07:44
I was looking at RDBMS but I found that the structure for RDBMS is different. My concern is that if I do export the users to text file using CSEUTIL would I be able to directly import this same file using RDBMS or I have to modify the structure of text file to be imported?
Thanks for the help,
