Cannot disable CSA on call manager
Jul 30th, 2007
We have CSA 4.5 on all Call managers (4.2(3). I am trying to install SR2 and before the installation I am trying to disable the CSA from services console. It gives me "Access is denied" message. I cannot stop nor uninstall.
I tried to stop/disable from the console but still the same message.
Can somebody help please
tsteger1 Mon, 07/30/2007 - 13:27
Typing "net stop csagent" at a command prompt didn't work?
You might be able to change the startup type in services to "disabled" and restart the system.
Tom
Amith Kumar Wed, 08/01/2007 - 04:59
Exactly. First time it didnt work using net stop command. Then I had to "Reset Cisco Security Agent" and again type the command net stop and then it worked. Earlier this executable was explicitly blocked by CSA itself.
Thanks Tom
