archive with SCP
Answered Question
Jul 30th, 2007
Hi all,
I have been using automatic archive configurations with TFTP and it works great. However, I'd like to switch to SCP as the file transfer mechanism to improve security on the router and for the file server. I have a test router configured with:
archive
path scp://user:[email protected]/file
time-period 5
This should automatically archive every five minutes with the specified username and password. However, it does not automatically archive, but I can manually archive by typing archive config. I visually watch the router successfully log in to the SCP server and put the file in the correct directory. Is SCP not supported for automatic archive or am I missing something?
thanks,
Correct Answer by Joe Clarke about 9 years 9 months ago
Hmmm, interesting. You might try "no archive" then re-enable archiving again. If that doesn't work, a reload would be in order.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 07/30/2007 - 12:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's working for me. What version of IOS are you running? What is the output of show archive?
sweigle Mon, 07/30/2007 - 13:41
Here is the show archive:
sho archive
The next archive file will be named scp://user:[email protected]/rtr01-11
Archive # Name
0 tftp://host/rtr01-15
1 scp://user:[email protected]/rtr01-1
2 scp://user:[email protected]/rtr012
3 scp://user:[email protected]/rtr01-3
4 scp://user:[email protected]/rtr01-4
5 scp://user:[email protected]/rtr01-5
6 scp://user:[email protected]/rtr01-6
7 scp://user:[email protected]/rtr01-7
8 scp://user:[email protected]/rtr01-8
9 scp://user:[email protected]/rtr01-9
10 scp://user:[email protected]/rtr01-10 <- Most Recent
11 tftp://host/rtr01-11
12 tftp://host/rtr01-12
13 tftp://host/rtr01-13
14 tftp://host/rtr01-14
flash:c2800nm-ipvoicek9-mz.124-11.XJ.bin
All of the above SCP archives were performed manually.
Here is my configuration:
archive
path scp://user:[email protected]/rtr01
time-period 5
thanks,
sweigle Mon, 07/30/2007 - 13:45
Hi again,
Is is what the output looks like when I perform archive manually:
rtr01#archive config
Writing rtr01-11
****USAGE WARNING****
This is a private computer system. This computer system, including all
related equipment, networks, and network devices (specifically including
Internet access) are provided only for authorized use. This computer system
may be monitored for all lawful purposes, including to ensure that its use
is authorized, for management of the system, to facilitate protection against
unauthorized access, and to verify security procedures, survivability, and
operational security. Monitoring includes active attacks by authorized entities
to test or verify the security of this system. During monitoring, information
may be examined, recorded, copied and used for authorized purposes. All
information, including personal information, placed or sent over this system
may be monitored.
Use of this computer system, authorized or unauthorized, constitutes consent
to monitoring of this system. Unauthorized use may subject you to criminal
prosecution. Evidence of unauthorized use collected during monitoring may be
used for administrative, criminal, or other adverse action. Use of this system
constitutes consent to monitoring for these purposes.
rtr01#
The file is written in the correct archive directory.
thanks,
sweigle Wed, 08/01/2007 - 07:14
I have some more information. The router appears to be not reset its timing of archive. For example, if I originally put 1440 minutes and then change it to 5 minutes. The router does not begin archiving at 5 minutes until after the 1440 time limit. Is there a way to manually reset the archive countdown?
Correct Answer
Joe Clarke Wed, 08/01/2007 - 07:44
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
sweigle Wed, 08/01/2007 - 08:47
thanks! I have tried it on the 3560G platform with c3560-ipbasek9-mz.122-25.SEE3.bin IOS. I experienced the same problem with SCP. Doing a no archive and adding the archive information does appear to work. I'll continue testing today.
Joe Clarke Fri, 01/07/2011 - 08:37
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I tested this on 15.1, and I looked through the code, and the password limit appears to be 31 characters. Please start a new thread for your issue and include the specifics about your device and config.
