Feedback on project Off premise extension
Jul 30th, 2007
I was wondering if someone in the group has ever come across the following scenario.
I would like to order a t1 channalized to the CO and have them mux it for me and run from the co a telephone line. The telephone line will ride a channel on my t1. Now i would like to take it a step further and configure the gateway with h323 dial peers and pointing to callmanager. Wonder if someone here has done that.
Paolo Bevilacqua Mon, 07/30/2007 - 12:52
There is nothing strange about that. It is called integrated access. Part of the T1 is data, part voice. The router supports that fine.
Paolo Bevilacqua Mon, 07/30/2007 - 13:50
No special documentation that I know, or you can search "integrated T1 access".
However under controller T1 you will configure channel-group for the data timeslots, ds0-group for the voice with the appropriate signaling type. Once this is done, serial and voice ports will be created, and you configure them normally.
jgittins1 Thu, 08/02/2007 - 13:18
This t1 will be configure for voice only no data so configuration might look like
controller T1 5/0
ds0-group 0 timeslots 1
dial-peer voice 1000 pots
destination-pattern 1000
port 5/0:0
Now you mentioned a signialing type how would i know what signaling type to use
do you have examples?
sarmentrout.qwest77 Thu, 08/02/2007 - 13:36
Why not request an ISDN PRI from the CO? If you do that, it comes in channelized already, has a D-Channel for signaling so you have 23 Bearer channels ultimately capable of handling calls if you want to ramp up...
controller T1 0/1/0
clock source internal
pri-group timeslots 1
trunk-group 1 timeslots 1
interface Serial0/1/0:23
no ip address
isdn switch-type primary-dms100 (or whatever your CO switch is expecting)
isdn bchan-number-order descending
no cdp enable
