Jon Marshall Tue, 07/31/2007 - 03:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Zahi
Not entirely sure i understand. You can use the IIS server as your root CA and issue a certificate to the CSS if that is what you mean.
If not plese let me know.
By the way for questions related to load balancing you would be much better posting into the following forum
Network Solutions -> Application Networking
A cisco specialist in load balancing hangs out there so he would be able to answer most if not all of your questions.
Jon
ZAHI ZEINEDDINE Tue, 07/31/2007 - 03:35
Thanks Jon for your response and soory for confusion. My question is about exporting a Certificate/key from IIS windows server and then import it to CSS. Would this work or I need to buy a new certificate from Verisign or any other vendor for this?
