IP Phone Agent
Answered Question
Jul 30th, 2007
I would like to install the IP Phone Agent but I am having a difficult time locating the IPAgentInitial.jsp file on my system. In the docuemntation, it tells you that a file called IPAgentInitial.class contains the inplementation but I can find this file either. I assume the file can be extracted from the .class file but not really sure. Any help would be much appreciated.
Correct Answer by lpezj about 9 years 9 months ago
The class file is a compilation of a jsp file. The jsp file contains the source code of the class file. Cisco doesn?t include the jsp files in CRS, so if you would like to access the class code you will need to use a decompiler for a class file.
When you call a jsp file from an URL, you are automatically redirected to the class file.
Hope this helps,
Juan Luis
Overall Rating: 0 (2 ratings)
Correct Answer
lpezj Mon, 07/30/2007 - 22:36
  • Gold, 750 points or more
Hope this helps,
Juan Luis
gtroussel Thu, 08/02/2007 - 08:11
Perfect, your answer helped a lot. I was a little lost in the document that Cisco provided. Thank you for your reply!!
lpezj Thu, 08/02/2007 - 22:33
Don't forget to rate helpful posts ;-)
Juan Luis
