What brand of analog phone to have MWI on VG224
Hi All,
I was wondering if anyone could recommend a brand of Analog phone that the MWI would work on a VG224.
I think the 224's can only support audible MWI but if they can do lights that would be great.
I have a customer that needs some analogs that can do the MWI on the vg224 and i do not have a brand to recommend. None of the phones they currently have (analog) will do the MWI on the 224's
thanks for any help
marknigh1 Wed, 02/13/2008 - 12:16
I recently purchased a "beehive" from the Mike Sandman at Chicago's Telecom Expert. I am unable to get it to work consistently with a vg224.
Does anyone have luck with getting these MWI FSK working with the vg224?
marknigh1 Wed, 02/13/2008 - 13:34
Thanks! I definitely have the VG224 setup as SCCP, but I am running version 12.4(6)xe3. I will upgrade to see if that helps.
I noticed the FSK turns on and off properly on the vg224 when i refresh the MWI but the beehive does turn on/off consistently.
Mark
dwindorski Fri, 04/25/2008 - 03:35
Mark,
Did you have any success getting this to work? If so what combination of code and MWI device did you find?
Dave
marknigh1 Fri, 04/25/2008 - 05:42
I did not since I am running CCM v4.1 and the VMWI is supported with v4.2 or higher.
alijames Mon, 05/12/2008 - 07:12
I have finally found a phone which does do VMWI on a VG224. It's a BT Converse 1300, so long as the MWI type is set to '1571'.
The VG224 is running SCCP on 124-15.T2 IOS on a CUCM 6.1.1 system
However, other similar phones in the range do not appear to work at the moment, Converse 1200, Converse 225 & Decor 1300.
TAC case open with Cisco. Watch this space...
Alistair
dwindorski Mon, 05/12/2008 - 07:19
Alistar,
Can you explain what you mean by setting the MWI type to '1571'? Is this some command on the VG224?
Dave
alijames Mon, 05/12/2008 - 07:32
Hi Dave,
No, the setting is on the phone handset itself. There is a selector switch on the back for MW1, MW2, MW3 & 1571.
Funnily enough, there is the same switch on the Converse 1200 as well, but no joy with that one...
Cheers,
Alistair
happyatuni Tue, 06/05/2012 - 17:44
Hello Alijames,
Just curious whether you know how CUCM or CME sends MWI to the analogue phones, does it do via:
1.     Broken Dial Tone
OR
2.     Burst of Ring (PRINGLE).
Cheers,
Hunt
cjoseph23 Fri, 11/21/2008 - 10:40
Phillip,
I have a VG224 running 12.4.22T connected to a telematrix phone but I cannot get the MWI lamp to turn on/off. Was there any special config you had on the VG? My VG is running SCCP and I see the FXS port registered to the CM.
I am able to place calls to the telematrix phone but the MWI Light does not work.
