VPN concentrator behind CSS
Jul 30th, 2007
I would like to set up a 3005 VPN Concentrator behind a CSS device.
How many services need to be set up for this?
Is the a sample config somewhere that would show what is needed?
Overall Rating: 5 (3 ratings)
Gilles Dufour Tue, 07/31/2007 - 01:13
do you want to loadbalance the vpn connections ? Or simply route the traffic through the CSS ?
For basic routing, no service is required.
Gilles.
wilson_1234_2 Tue, 07/31/2007 - 03:21
I want to do a failover solution to a different ip subnet, but use the same DNS name.
So, You can call it a load balancing situation.
I will need to set up a VIP and services and a service group maybe?
Can I do that?
Gilles Dufour Tue, 07/31/2007 - 07:19
the CSS does not support ipsec traffic.
So you'll need to use your vpn in tcp/udp mode.
Just want to make sure you are aware of that.
If tcp/udp mode, you will then configure the CSS just like if the vpn was a server [like http].
So you create a service for the vpn address, then a content rule using this service.
A group is only required if you need to nat the client ip address ie: to guarantee that the response from the vpn goes back to the css.
With this config, the css will nat the destination ip [the vip] with the vpn ip [service ip].
I'm not a vpn expert but I assume this is ok. If not, you can configure the service to be in transparent mode.
Gilles.
wilson_1234_2 Tue, 07/31/2007 - 08:14
Thanks for the reply,
So,
When you mentioned this:
"The CSS does not support ipsec traffic.
Just want to make sure you are aware of that."
Were you mentioning this from a security perspective?
Gilles Dufour Tue, 07/31/2007 - 22:58
no, in terms of security ipsec or ipsec over tcp are identical.
Just wanted you to know that plain ipsec would not go through the CSS.
Gilles.
