Authorisation between Concentrator and ACS 4.1 not working.
Jul 30th, 2007
I have a vpn 3005 concentrator in a dmz, directing authentication and authorisation back to a ACS Radius server. Authentication works fine, however as soon as I attempt to have the ACS server authorise as well, I received a Radius Access-reject(3) packet from the ACS Server.
rochopra Tue, 07/31/2007 - 03:15
Do you have 2 seperate radius servers ?
why are you implementing authorization for vpn?
Anonymous (not verified) Tue, 07/31/2007 - 15:25
Just 1 RADIUS server.
I though you need authorisation to push out various settnigs like NAC, IPAddressing, DNS Server addresses etc.
Whenever I just have authentication, I can vpn in fine, however no settings come across from the ACS server?
Anonymous (not verified) Tue, 07/31/2007 - 19:04
Thanks for that.. I have setup just authentication and have successfully pushed out various settings, and downloadable ACLs. All worked fine.
Thanks again.
I had trouble with replying to your post, which is why you see 3 blank posts below :)
rochopra Wed, 08/01/2007 - 11:28
do rate helpful posts so that others can benefit from it
Anonymous (not verified) Tue, 07/31/2007 - 19:05
