Aironet 1030 REAP
Jul 30th, 2007
I have WLC with 3 SSID's. 1st SSID is with encryption WPA-PSK, second is with web authentication and third is no security policies. I have primed the AP in the local subnet. The REAP AP managed to find the controller and associate, but only managed to see one SSID, which is the one without security policies.
I have tried to change the settings in the WLAN override, but still the same.
Appreciate your feedback.
pradeepde Mon, 08/06/2007 - 06:14
  • Bronze, 100 points or more
This might be a fragmentation issue. Check for the MTU in the Path. You can also try to reboot the access so that it tries to associate.
