PIX 515E: from OUT to IN without NAT
Jul 30th, 2007
Hello!
On PIX 515E I need access from a real IP x.x.x.x (outside interface) to inside IP 10.1.1.2 (inside interface) without NAT - for test purposes.
When I try to access from the real IP x.x.x.x inside IP 10.1.1.2 PIX sends error messages to syslog: (305005) "No translation group found for icmp src OUT:x.x.x.x dst IN:10.1.1.2 (type 8, code 0)".
I tried 2 configs:
1. access-list nonat_toInside extended permit ip host x.x.x.x 10.1.1.0 255.255.255.0
nat (OUT) 0 access-list nonat_toInside
2. static (OUT,IN) 10.1.1.2 10.1.1.2 netmask 255.255.255.255
But nothing helped... May be there are mistakes? Or what should I do to solve the problem?
Overall Rating: 4.3 (3 ratings)
Jon Marshall Mon, 07/30/2007 - 23:06
static (inside,outside) 10.1.1.2 10.1.1.2 netmask 255.255.255.255
+ allow icmp on your access-lists
Jon
abatuyeva Tue, 07/31/2007 - 01:57
The problem is still remaining.
If I write "static (outside,inside) 10.1.1.2 10.1.1.2 netmask 255.255.255.255" I see on "show nat" this:
NAT policies on Interface Out:
match ip Out host 10.1.1.2 IN any
static translation to 10.1.1.2
translate_hits = 0, untranslate_hits = 0
If I write your command "static (inside,outside) 10.1.1.2 10.1.1.2 netmask 255.255.255.255" this rule appears on interface IN and PIX doesn't want to translate again.
Why nat 0 desn't work?..
mattiaseriksson Tue, 07/31/2007 - 02:04
nat(0) only works for inside to outside dynamic translations.
In your case you need a static like jon.marshall suggested:
(outside,inside) is only used if you want to translate the outside source address.
srue Tue, 07/31/2007 - 20:01
or add icmp inspection to the global policy.
abatuyeva Wed, 08/01/2007 - 01:26
Sorry, Jon, I wrote wrong IP to my config :[
So, your answer helped me!
Thanks!!
P.S. I've forgotten to check a box that the post resolved my problem. But now I'm not allowed to do this...
