Can the CSS operate in bridged mode with multple subnets?
Jul 30th, 2007
The white paper below notes that the CSS CAN operate in bridged mode but it is not recommended. Is it possible to load balance more than a single subnet while operating the CSS in bridged (single VLAN) mode? I would like to test how effective it is despite the warning. Thanks.
http://www.cisco.com/en/US/products/hw/contnetw/ps1894/products_white_paper09186a00801bd4ae.shtml
Overall Rating: 5 (2 ratings)
Gilles Dufour Tue, 07/31/2007 - 01:15
you can bridge with multiple subnets.
But the CSS will route between the subnets when it can. The bridged interfaces are not independent.
Gilles.
mmedwid Tue, 07/31/2007 - 06:42
How would you get the CSS to recognize and balance the multiple subnets on a single bridge/VLAN? Thanks for both your answers so far Gilles.
Gilles Dufour Tue, 07/31/2007 - 07:36
you can assign multiple ip from different subnets to a single circuit vlan.
You link the physical interfaces with the "vlan" command. Then assign ip addresses under the circuit-vlan.
The CSS will bridge traffic on physical interfaces belonging to a same vlan.
I hope this is what you need.
Gilles.
mmedwid Tue, 07/31/2007 - 07:54
I thought I had tested that configuration to a no-go. But based on your feedback - I'm going to have another go at it. Maybe I missed something. Thank-you very much.
