Request timed out when pinging other VLAN ip's on VLAN environment
Jul 30th, 2007
6509 - 1 No. with Sup-II of 2 No. standby also 3750(3 switchez stacked) hsrp configured. 22 VLANs are there configured & working for the past 2 yrz with no probz. since sterday after when i ping to the local gateway from any of the VLAN or any ip address from 1 vlan to other VLAN, once in every 20-30 ping reply, i get request timed out. if there is a loop, then it will affect only 1 particular VLAN, bcoz i hav already experienced such probz long time back, but this probz i am not getting any idea what could be, bcoz if i ping from the any vlan to other vlan i get request timed out, even when i ping my own gateway also i get request timed out, any help would be highly appreciated.
CPU,Back plane traffic is normal, any other trouble shooting method do i need 2 follow for identifying?
Edison Ortiz Tue, 07/31/2007 - 06:22
I'm assuming the gateway is the HSRP VIP ?
Did you create different HSRP group number for each Vlan within the standby commands ?
I recommend doing one Vlan (different number from the rest) and verify if the request time-out issue goes away.
Anand S Tue, 07/31/2007 - 06:27
since 6509 supportz max 16 groupz for some groupz they r all same group number, but this is working fine for the past 2 yrz. k fine it this is the case how this is impacting the network with the "request timed out"?
Edison Ortiz Tue, 07/31/2007 - 06:33
It could be duplicate ARP entries within a Vlan or duplicate IP address.
Can you try what I suggested and then we move forward if it doesn't work ?
I recommend checking the ARP table on both the 6509 and 3750 and see if the src/dst ip that you are pinging have the same mac-address.
Anand S Fri, 08/03/2007 - 08:52
Hi Edison,
i tried the option which you told me, but ended up with the same result, but later in the mid night i have tried disconnecting each up link from the main switch, finally i could find that one of the switch was creating the probz when i tried disconnecting & connecting again, after removing that switch from the network & configured an alternate, the probz was solved. Thankz edison for ur trouble shooting method which u hav suggested, even though the solution which u hav told didn't solve my probz, but i would appreciate for the initiative for trouble shooting.
