paolo bevilacqua Tue, 07/31/2007 - 00:13
  • Hall of Fame,
    Founding Member
Put files on tftp server, make sure your DHCP server has option 150. Turn-off phone, press # while turning on, release # when led flash in sequence. Press 0123456789*0#. Phone will reset, get address via DHCP and look for term70.default.loads, and then the other files.
seegomaa Tue, 07/31/2007 - 00:22
many Thanks for your reply. there is one thing that i have no DHCP so what will i do
