New Active IKE Proposals "CRACK" when upgrade from 4.1.7 to 4.7.2
Jul 30th, 2007
You may remember me from such conversations as "Can't login to web GUI since upgrade" ... and while trying to fix that problem I came across a couple of newly installed Active IKE proposals, namely:
CRACK-3DES-SHA-DH2
CRACK-AES128-SHA-DH2
Just a bit interested in these. Why were they installed into config after upgrade? Also why are they called "CRACK"?
Any ideas?
Mike
drolemc Mon, 08/06/2007 - 11:45
I think CRACK-3DES-SHA-DH2 and CRACK-AES128-SHA-DH2 are the new IKE proposals added.
