07-30-2007 11:51 PM - edited 03-05-2019 05:35 PM
Hi Experts,
If I'm using VTP , then i want to know from which switch my existing switch receive it's VLAN infromation.
07-31-2007 12:14 AM
Hi Friend,
If you run "sh vtp status" in the last line you will see the ip address of the switch who had updated this VTP client switch.
Switch#sh vtp status
VTP Version : running VTP1 (VTP2 capable)
Configuration Revision : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs : 22
VTP Operating Mode : Transparent
VTP Domain Name : NULL
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x07 0x0A 0xC2 0xEC 0x1D 0xEE 0xC8 0x1B
Configuration last modified by x.x.x.x at 0-0-00 00:00:00 <<<<<<------
Ankur
*Pls rate all helpfull post
07-31-2007 12:26 AM
Thanx Friend ,
exactly what i want is the name of the switch who gives my existing switch it's VLAN not it's IP address.
BR ,
Ibrahim Alwahidi
07-31-2007 01:54 AM
You can only get the name if you have an entry for the IP address in your DNS.
CDP would show you the name but you would have to be lucky enough to be on a switch that is connected to the root bridge.
Jon
07-31-2007 02:23 AM
Hi Jon,
Thanx for your answer , assume that the existing switch connected directly to 2 switches and one of them is root bridge , so show cdp neighbors detail command will display the ID ( hostname ) for the connected switches and their's ip addresses not MAC address to trace the root bridge , so if the root bridge doesn't have an ip address????!!!
BR,
Ibrahim ALwahidi
07-31-2007 12:16 AM
Hi Alwahidi,
YES u can find from which switch ur existing switch has got the vlan information, juz type " "show vtp status" in that last line showz the ip address from which it has got the vlan information. below is the output of my existing switch in my network
3750#sh vtp status
VTP Version : 2
Configuration Revision : 9
Number of existing VLANs : 8
VTP Operating Mode : client
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
MD5 digest : 0x13 0xE3 0x1E 0xB3 0x6B 0x2E 0x18 0xCB
Configuration last modified by 172.19.1.1 at 3-1-93 01:05:42
Local updater ID is 172.19.1.1 on interface Vl1 (lowest numbered VLAN interface
found)
i hope this helps. lemme know if anything else has to be clarified.
07-31-2007 02:00 AM
Hi Ibrahim,
you will not get the name of switch until unless you are using DNS
or If you are trying to figure out if this possible then I can suggest you one thing, if CDP is enabled :-
trace the mac-address of switch and use show cdp command set to check the out the hostname.
rgds
