netflow in Cisco 6513 with SUP 720
Jul 31st, 2007
Hi Experts
We are having two cisco 6513 switches with SUP 720. One with IOS 12.2.17d-SXB11 and other with 12.2(18)SXD7b. I have configured netflow in both the switches. The switch with IOS 12.2.17d-SXB11 is working fine and I am able collect netflow statistics for both in and out where as I am using the same configuration with my other switch with IOS 12.2(18)SXD7b, it can only recive the netflow for in but not for out. So what do you think the problem might be , is the configuration has to be changed ? becoz of other IOS ? please let me know.
Here is config
SWITCH with IOS 12.2.17d-SXB11 - WORKING for in and out
mpls ldp logging neighbor-changes
mls flow ip interface-full
no mls flow ipv6
mls cef error action freeze
interface Vlan1
no ip address
shutdown
interface Vlan50
description NETMANG
ip address 50.0.0.2 255.255.255.0
ip helper-address 10.0.1.100
ip helper-address 10.0.1.101
ip nbar protocol-discovery
ip route-cache flow
standby 52 ip 50.0.0.1
standby 52 timers 5 15
standby 52 preempt
interface Vlan100
ip address 10.0.0.54 255.255.248.0
ip directed-broadcast 101
ip route-cache flow
standby 10 ip 10.0.0.10
standby 10 timers 5 15
standby 10 preempt
ip flow-export source Vlan100
ip flow-export version 5
ip flow-export destination 10.0.0.1 9996
ip flow-export destination 10.0.0.6 9996
ip http server
logging trap notifications
logging 10.0.0.2
logging 10.0.0.6
logging 10.0.0.5
access-list 101 permit udp host 10.0.0.6 any eq echo
snmp-server community xxx RO
snmp-server community xxxr RW
snmp-server ifindex persist
SWITCH with IOS 12.2(18)SXD7b - NOT WORKING (Working only for IN)
mls ip multicast flow-stat-timer 9
mls aging long 128
mls aging normal 32
no mls flow ipv6
mls nde sender
interface Vlan1
no ip address
shutdown
interface Vlan50
description NETMANG
ip address 50.0.0.3 255.255.255.0
ip route-cache flow
standby 52 priority 50
standby 52 preempt
interface Vlan100
ip address 10.0.0.55 255.255.248.0
ip route-cache flow
standby 10 priority 50
standby 10 preemp
ip http server
snmp-server community xxx RW
Cheers
Yasir
Jan Nejman Tue, 07/31/2007 - 03:06
I think that it can be a normal situation, because all traffic goes to the "HSRP selected" GW (in your case sw #1). The sw #2 is receiving only HSRP hello messages from sw #1.
Bye
Jan Nejman
Caligare, Co.
http://www.caligare.com
