wav files deleted - don't know why!
Answered Question
Jul 31st, 2007
Hi all,
I have a new-installed IVR4.5 server, but I am facing with a problem: when the server reboots or shutdowns (suddenly or planned), all the wav file in the folder C:\Program Files\wfavvid\Prompts\user are deleted. They are the files for our prompts, so when they are deleted, the applications cannot work well.
I'm very confused with this, could anyone give me some troubleshooting guide?
hoanghiep
Correct Answer by Gergely Szabo about 9 years 8 months ago
all prompts must be uploaded to the repository as suggested by Juan Luis.
If you just copy/save the prompts on the disk, they will disappear, since CRS does not know about them.
Actually, what you can do is to create a dedicated folder on the CRS server, for instance C:\prompts\app1, where, for instance, prompt1.wav and prompt2.wav will be stored. Then you can use in the script editor the following: Play Prompt FILE["C:\prompts\app1\prompt2.wav"]
Of course, this dedicated folder must be off the CRS install dir (by default, it is C:\Program Files\wfavvid
Correct Answer by lpezj about 9 years 8 months ago
I think that you have to add the prompts to the Directory. In the AppAdmin web page go to 'Applications' -> 'Prompt Management' and go to the directory where you have the wav files, and click on 'Upload new prompts' and add the prompts that you are going to use in your scripts.
Hope this helps,
Juan Luis
Overall Rating: 5 (2 ratings)
Correct Answer
lpezj Tue, 07/31/2007 - 02:35
  • Gold, 750 points or more
Hope this helps,
Juan Luis
hoanghiep Tue, 07/31/2007 - 02:45
Thanks for your quick reply,
But with another CRS system, I copied the files to the user directory (I did the same way for both systems) and it works well (exist there untill I delete them :) )
By the way, I will try your recomendations with my system.
Any other ideas?
hoanghiep
Correct Answer
Gergely Szabo Tue, 07/31/2007 - 03:46
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
hoanghiep Tue, 07/31/2007 - 04:08
Yes, thanks for your recomendations. They solved my problems.
hoanghiep
sferland Tue, 07/31/2007 - 11:19
  • Bronze, 100 points or more
With the introduction of the HA (High Availability) in version 4.0, all the prompts are now injected as binaries into the repository (database) and are written on disk for your application. This mecanism is used for replication between two or more CRS servers in case of failure.
If you just copied them to disk without "uploading" them to repository, it will works for your application, but the next time the system will reboot or restart, the CRS will overwrite all prompts on disk by those in the repository.
If was not the case with version prior to 4.0.
