CM 5.1.2a Connection Broken
Jul 31st, 2007
I,
I have a cluster with 1 pub and 1 sub, i have upgrade the to nodes to 5.1.2a.
The upgrade did not return any error, after te upgrade i was unable to acces the service parameters of the sub from the publisher. Also from the subcriber if i do a find for same DN I get the folowing error:
java.sql.SQLException:System or internal error java.net.SocketException:Connection timeout.
I have connectivity between the sub and the pub. I alredy reload the sub but it is the same after the reload.
Cam any one have any ideas.
Majdi Harb Tue, 07/31/2007 - 03:02
  • Silver, 250 points or more
what the upgrade sgn file/s did u use?
patcbr600 Tue, 07/31/2007 - 03:08
I,
I use cisco-ipt-k9-patch5.1.2.2000-3.tar.gz.sgn
